B
burbeck
When someone at our church tried to record audio into a laptop this
caused a serious racket if line powered. Probably this is due to the
laptop switch mode power supply. Only running the laptop off its
battery produces a decent recording. Is there a simple balun
transformer that you could recommend?
It is out of the main mixel panel at line level. This source feeds
other things such as a speaker amp, hearing wands etc. Those didn't get
disturbed so it looks like the laptop is "self polluting".
No. You need to take the brute force method. An isolation
transformer connected to the PA amp's speaker outputs and a two stage
attenuator to reduce the level to what you want. get a 25, 70 or 100
volt audio line transformer and connect the low impedance side to the
speaker line.
Common problem with laptops. The psu is usually a 2 wire job , so
there's no nice clean earth for the Y caps in its EMI filter.
j.b. miller said:How about using the common 'telephone 600r-600r' type transformers ? Easy to
find,just hack any old PC modem card.or if you have access to an old Amtelco
concentrator, they have great audio transformers in there!
jay
Joerg said:Hello Folks,
laptop switch mode power supply. Only running the laptop off its battery
produces a decent recording. Is there a simple balun transformer that
I know the Muxlab (Montreal) versions which have great frequency
response. However, these are rather bulky devices that are ok for a
fixed installation. But this one needs to be small and portable even if
it's not 100% "hifi".
Ok, of course I could make one. But if there is a smaller of-the-shelf
version that would be better.
Regards, Joerg
John said:I read in sci.electronics.design that Pooh Bear
What Y caps? For a 2-wire, there is no point in including a Y cap.
This or similar might help
http://www.rohm.com/products/databook/audio/pdf/ba3121.pdf
But those have very poor CMRR for radiated RF! Just what is NOT wantedIf you're going to have active circuitry a simple differential input
op-amp configuration will do the job at better quality.
I don''t know what you wanted me to look at but I looked at the EPR11See some applications schematics at www.powerint.com. I'll see if I can
dig out the relevant ANs in the office.
John said:I read in sci.electronics.design that Michael A. Terrell
I REALLY would not recommend this. Why transform the audio up to 25 V or
more only to attenuate it again?
Pooh said:If you're going to have active circuitry a simple differential input
Graham
I did this because it was usually the only decent audio transformer
available when I needed to build another interface in a hurry.
in this case (if what the OP thinks is the cause is indeed the cause).
1: I did this because it was usually the only decent audio transformer
available when I needed to build another interface in a hurry. I just
use the pair of pots when there is no hum problems. BTW, the highest
wattage tap on the transformer has the lowest voltage. If you use the
16 ohm winding and a 5 watt tap the voltage doesn't go up very much.
The highest voltage is on the lowest tap, or 25 volts. Not only that,
but the voltage only reaches 25 volts at the full rated output of the
amplifier.
2: A good 600 ohm to 600 ohm transformer can be expensive and hard to
find in a hurry. I have a pile of crappy mil spec 600 ohm to 600 ohm
transformers that roll off a little over 2.5 KHz and others that aren't
much higher quality.
J said:useful transformers are not difficult to find if you know how an audio
transformer looks like, you probably have a lot of equipment where
they are without considering it. Impedance is not important when the
equipment hasn't been made to a specific impedance
Jan-Martin
