georgegr79
- Feb 24, 2017
- 8
- Joined
- Feb 24, 2017
- Messages
- 8
Hello!
I just received yesterday my "new" 2235.Buyed really low for repair item.
Now here is the problem,when i plug it and turn it on it makes this "chew" repeated sound and the led in the face blinks.The two of the three lamps in the power supply area blinks too.
I have tested the CR960-61-62-63.Two of them found faulty (buzzer beeps on the multimeter).After i desolder them to check them again they was ok!I then tried to plug again the scope and turn it on without the two diodes.The scope turned on,without weird sounds from the supply a dot left in the screen appeared.Only the dot and i can control only the focus.
I think for a fault capacitor that maked a short circuit????
i have removed CR960-962.
What type diodes can i use?because i cant find the same.
George
George
