Steve & Julie said:
I would like to know what is the internal difference between AC and DC
relay?
Why the AC coil works on DC power and not DC coil on AC power?
Sorry for my english, I'm french!
With an AC source, the 'pull' pulses 120 times a second (100 times a second
on 50hz). This uneven magnetic pull causes the relay to chatter/buzz. AC
coils deal with this by putting a short-circuited shading coil around 1/2 of
the pole face. The eddy currents induced in this coil build up a magnetic
field. Because of the inductance, the current in this coil is out of phase
(time shifted) from the main current. So although the magnetic field in
this section of the pole face alternates at 120 hz (or 100hz), it crosses
zero at a different time than the rest of the pole face's magnetic field.
Result is a steadier 'pull' and no chatter.
Keep in mind that many AC coils can *not* be used on DC of the same voltage.
AC coils often rely on the inductive reactance of the coil to limit current.
Connect them to DC of the same voltage and the current will be excessive,
and the coil can burn up.
daestrom
