About TV Repair: How do I disconnect Anode connection from Circuit board?
Discussion in 'Electronic Repair' started by Red Cloud, Jun 8, 2007.
  1. Red Cloud
    Red Cloud Guest
    I'm trying to disconnect CRT from main circuit board on my 27" Sony
    Trinston? I did disconnect all the wires except the Anode Connection
    wire (red color). I tried to pull out from the power source on main
    circuit board, not from CRT. It just did not come out.
    What do I have to do? Is this wire a clipped or not?
  2. Arfa Daily
    Arfa Daily Guest
    It should be a wire or pressed steel sprung clip, which fits into what is
    called a 'cavity connector' on the CRT bowl. For most CRTs, removal requires
    that the edge of the 'poppy' is gently lifted from the bowl, until you can
    see the actual metal contact, and then by pressing on one side of the
    contact, with the tip of a thin screwdriver shaft, until it bends in enough
    to relase on one side. The other side can then just be lifted out.
    BEWARE. Much lightning lingers in that cavity connector, and can do for a
    very long time after the TV was last powered. Do take care lest this
    lingering lightning smites thee ...
    Arfa
  3. Red Cloud
    Red Cloud Guest
    Thanks for rebut this but..
    I don't wanna pull it out from CRT bowl. The other side was not
    coming out last time I tried to lift up hard. It just did not come
    out. Well I tried again...
  4. PeterD
    PeterD Guest
    That's your only option. THat is the way it is meant to come out.
    You are doing something wrong... <g> Go back and *look* carefully at
    the connector at the tube. This is not rocket science, you'll figure
    it out. Trying to 'disconnect' at the other end will only break it.
  5. Gary Tait
    Gary Tait Guest
    You have to, tht is the way nearly all anod leads disconnect.
