L
Leon
Paul Horowitz is involved in this project:
http://news.bbc.co.uk/1/hi/sci/tech/4907308.stm
Leon said:
72 inches is a rather tiny mirror for such an ambiguous
project.
And I'd have had expected a microchannel plate in front
of a higher resolution CCD array.
Winfield said:Rene Tschaggelar wrote...
Did you mean ambiguous or ambitious?
A 6-foot mirror can gather plenty of light - and it's
larger than the first oseti experiment, which suffered
more from having only two PMTs than from mirror size.
A PMT can do a fine job of grabbing single photons.
In this case each of Paul's 1024 PMTs will distinguish
between one, two, three, etc, or more photons, in the
expected all-photons-at-once pulses one would get from
an artificial pico-second laser flash. Furthermore, a
similar intense pulse must be seen by a second set of
PMTs observing the same light flash via a beam splitter.
After this multi-photon nanosecond-scale PMT pulse there
must be only background light, which consists of modest
photon rates. No natural source of light has such a
signature. The basic scheme has been proven in years
of use, see the detailed physics papers on the website.
http://seti.harvard.edu/oseti/
Paul Hovnanian P.E. said:Interesting. But it would be a real shame if this detector was only just
sensitive enough to pick up the photon signature of distant
civilizations as they annihilated themselves in one final planet-wide
thermonuclear war.
Tim said:"Paul Hovnanian P.E." ... wrote i...
PMTs and mirrors don't pick up X or gamma rays. ;-)
Winfield said:[snip]
Imagine an advanced civilization that hasn't blown itself up.
They're rich and a bit bored. Interstellar distances are too
large to travel to other stars, or at least beyond the close
ones, so they spend some time and money on an interstellar
communication channel. Assuming such civilizations are out
there and have made the transmitters, why not listen in? In
early seti research it was assumed radio communication would
be used. But now that we know how to make the appropriate
lasers, it's clear that high-power pulse laser communication
is much better (each pulse outshines the adjacent sun) and
would be used, hence the new field of oseti, optical seti.
James Waldby said:Yes, I'm sure you're right ~ those X-ray mirrors in
XMM-Newton and Chandra must be just tinsel decorations.
Winfield Hill said:In this case each of Paul's 1024 PMTs will distinguish
^knownphoton rates. No natural source of light has such a
To my knowledge, PMTs don't work great with ionizing radiation, though.
That's a spectrum for a different detector.
Paul Hovnanian P.E. said:The other factor which would affect the wavelength question is which
parts of the spectrum would one select that have the lowest probability
of being mistaken for some natural phenomenon.
Paul Hovnanian P.E. wrote...
Indeed, but Paul's telescope's oseti-processing is tuned to
intentional very short high-power laser pulses, and would
therefore ignore the optical signal from such an event. The
telescope electronics does have an "astronomy" channel which
might see some of a large explosion, but even so its single
photon-at-a-time nanosecond pulse-intensity processing engine
would become overwhelmed, and ignore most of such a signal.
For example, the photon flood from a nearby lightning strike
would not be confused with the sub- to few-nanosecond pulses
Paul's telescope's electronic processing is looking for.
Rich said:[snip]
Then again, by the time they get so advanced to have an interplanetary
civilization, they might well have discovered telepathy or subspace
radio, or something we've never even dreamed of, which we don't know how
to receive yet. ;-)
how
to receive yet. ;-)
I've wondered about this for some time, and didn't know if it was being
done. (I posted the thought on a forum or two and the thought was
dismissed).
My own take on the idea (cw emissions from modest sources) might be why,
but to me it's still an interesting idea.. How powerful do the pulses have
to be? Could we detect CW? There is one source of CW that we might easily
look for. Amateur and professional astronomers have both used lasers to
guide scopes, and if the laser is tracking a star, and pointing at it,
might some pulses be detected as a constant train? Especially in the case
of copper vapour lasers, which make small highly intense pulses
continuously. One thing about a planet full of people with lasers is that
there might always be something pointing from one star to another, so might
it be just a case of analysing the stars' light a bit more closely?
I seriously doubt if anyone who has the power to communicate between
star systems would use electromagnetic radiation to do it. What's the
status on gravity waves these days? How about quantum black holes? ;-)
Thanks,
Rich
