With a single rectifier you get sqrt(2) * 220V from 220V AC without a series regulator.
That would have required at least one extra tube.
While 310 V would be the _no_load_ voltage on a capacitor after a
diode with zero voltage drop, the real situation was quite different.
With tube rectifiers and selenium stacks, the voltage drop was quite
significant. Those rectifiers do not handle well large peak currents,
thus it is out of the question to just have a large electrolytic
capacitor after the rectifier. In practice, choke input filtering (or
at least CLC filtering) had to be used to extend the rectifier
conduction angle and hence avoid large peak currents. A form of power
factor corrector
Some radio receivers did not have permanent magnets in the
loudspeaker, but an electromagnet coil was used to create the static
magnet field, in which the actual voice coil moved. The electromagnet
coil doubled as the power supply choke
Due to these factors, the normal loaded anode supply voltage was about
200..250 Vdc for AC/DC radio/TV receivers with a half wave rectifier.
The old U type radios (150 mA heaters wired in series) may have had a single recifier.
U series is 100 mA.
I got an AC/DC receiver from my grandmother, who had previously been
living in an apartment building with 220 Vdc. It had UY1N half wave
rectifier, two UCH?? triode/heksode and an UL?? power pentode. Working
inside AC/DC receivers can be a bit dangerous, since the chassis can
be at full mains phase voltage. Quite quickly one learns to make marks
on the plug as well as close to the socket, so you know, which way to
insert the plug
All P type (300 mA wired in series) *color* TVs I have seen had a Si bridge rectifier.
As color did not start here until 1967, si bridges were common.
Due to the late introduction of colour TV in Europe, only a few
generations of TV sets were made with tubes, in 1972 receivers with
CRT as the only tube were available.
Some very early BW TVs used a PY82 tube rectifier.
http://www.radiomuseum.org/tubes/tube_py82.html
All these sets worked at a much higher anode voltage than 200V DC.
Take a look at for example
http://frank.pocnet.net/instruments/Philips/HR/TV/TV-docs/21CX211A/21CX211A.pdf
the power supply is on page 11.
With 220 Vac input, a 220 Vdc supply line from the first capacitor is
available with high ripple voltage. After the S1 choke and a few large
capacitors, 205 Vdc is available at low ripple.
For radio tubes, the Telefunken 1964 Tascenbuch uses an example
configuration for UY85 with 220 Vac mains and 215 Vdc anode supply at
110 mA with a 100 uF capacitor.
