DJ Delorie
I'm working on a circuit with a RTC that uses the ubiquitous 32768 Hz
crystal. I'm assuming my problems at the moment are due to using a
solderless breadboard and not a properly laid out circuit board, but
just in case I'm missing something obvious...
My RTC is running a little fast (8%!). I'm pretty sure it's picking
up glitches from nearby wires (no ground ring, etc), and there are
some step pulses on the sine wave which confirm this. But could
someone verify the signals otherwise? The IC's drive signal is 1v
peak, but not a sine wave - it's clipped to ground for about 30% of
its phase, and has a faster drop than rise. The drive signal after
the 330K is a 0.8vpp (0v-0.8v) sine wave. The return signal is a
0.5vPP sine wave centered at 0.8v. Do these sound right? I'd rather
at least get this part right before having a board made.
The circuit is an ECS-1x5 crystal, 330K series R, 15pF caps, into a
microchip PIC24F (3.3v). The load's a little off (8.5 vs 8 pF) but
that's as close as I can get with the caps at hand.
Would a crystal that needs higher load caps be more noise-immune? I
seem to get that opinion from various readings.
Would adding 50R resistors to the pins near the crystal help any,
assuming I've done the usual ground ring and keepouts?
Thanks,
DJ
Thanks,
DJ
