S
Sidney
27" Magnavox stereo tv model:XS2744A402,chassis:27Y104AA,year:Aug
1993,wood grain immitation case.One day the tv would not turn on upon
troubleshooting I found the following to be defective:
Q502=S2055AF=Philips # 4835 130 47897=NTE # NTE2353=2SD1878
F401=2.5 amp fuse
C432=100 Uf,200v
bad solder on:
R504
R524
R400A=degauss thermistor
K400=relay
I checked:
IC400=STR30130
R403=1.5 ohm,7w
Q400=TIP47=Philips # 4835 116 57108=NTE198
and they are fine but I briefly could not find R432=1K ohm,1/2w so why
would the Q502=HOT fail? and is F401 a pico fuse?if so my local
supplier only has a 2 amp or 3 amp which can I use?.Thanks in advance
for help.
Sidney
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
F401=2.5 amp fuse
C432=100 Uf,200v
bad solder on:
R504
R524
K400=relay
I checked:
IC400=STR30130
R403=1.5 ohm,7w
for help.
Sidney
Canada
