Hello there,
I am thinking of making a basic changeover switch for 220AC. There will be 2 (L - Phase) inputs and one out put line which goes to a 220V-20W CFL Bulb. One input line is coming from the main AC line and other is from some other 220V power base like battery with inverter. When there is power on main line the relay switches it on and if the main line goes down (a power failure) the changeover switch switches on the alternate power source. It will not help to keep the bulb on for 24 hour without any disturbance.
Are there any relay based low cost switches (because I have many lights to switch on)
Or is there a way that diode based switch can be used?
Thanks a lot in advance.
Nishan
Nishan
