captoro said:
The Idea here is to power a house. I have 11 batteries being charge
by solar and wind power. I thought it would be simpler just to convert
120VDC to 120VAC then 12v to 120cAC. A 5Kw inverter is expensive, but
the way I want to do it, I am saving myself the boost of voltage.
Ken
There are some serious issues here.
You'll be drawing in the neighborhood of 50 amps from each of the
batteries to get ~5kw. That means you want some heavy conductors
to put the batteries in series - think automobile battery cables
for size. They will need to be switched out of series if they
are charged individually from your sola5r and wind sources. If
they are switched out of circuit for charging and back into
series when powering the load, you'll need switching circuits
that can carry that relatively high current with low loss.
None of that is a "show stopper" but it *must* be addressed
in the design. And that needs to be addressed _before_ worrying
about how to build the inverter - i.e. there's no point in
having the inverter you want if you cannot provide it with the
needed input power.
Safety is a huge issue. If you do not know how to accomplish
what you want, then you *cannot* know how to address the safety
issues.
Cost. The inverter/batteries/solar&wind charger setup will
cost you WAY more than a 5 kw gasoline powered generator.
You need to figure the run costs to see if your plan has
merit. If it is just for backup when the grid is down, the
gas generator is the way to go. If it is a house that is
far from the grid and far from a supply of gas, solar/wind
may be viable (or possibly the only real cost effective
solution). You need to work out a detailed energy budget
and compare.
Space. You need to consider how much space is available to dedicate
to whatever equipment you use to provide the 120VAC, and you need to
consider the reguirements of that equipment - airflow, ambient
temperature, service clearance etc.
Location. Part of the engineering is determining whether there
is enough solar/wind energy available at your location to make
the effort worthwhile.
As a general rule, solar/wind is not a viable alternative to
grid connection to power a house.
You indicated that you already have batteries being charged by
solar/wind. That *might* give you a leg up on some of the issues
mentioned above - but it might not.
Ed
