100V switch
stari
Oct 24, 2015
18
Oct 24, 2015
18
i have 100V output from converter and i wish to switch tis line with cca. 3V from microcontroller. I have driver, yes, but with poor results. Can anybody sugest how to make such a switch. !00V sould be switced on and off with frequency from 10 to 100 Hz.
tedstruk
Jan 7, 2012
476
Jan 7, 2012
476
you need down converters with relays between them. Frankly they say its alot of money and work to go to, when a seperate converter is available for lower volts. easier to install a second converter.
AnalogKid
Jun 10, 2015
2,895
Jun 10, 2015
2,895
Your question and schematic are missing critical information.
Where on the schematic is the 100 V input?
Where on the schematic is the 100 V output?
Which signal on the schematic is the one that switches the 100 V on and off?
What does "cca. 3v" mean?
ak
stari
Oct 24, 2015
18
Oct 24, 2015
18
Hi
100v is generated with Q1 and output is on D1*C1.
PWM controls the output voltage.
CTRL signal switches 100V on/off.
3V is Vcc.
So simple.
AnalogKid
Jun 10, 2015
2,895
Jun 10, 2015
2,895
What are the "poor results"? In what way does the so simple circuit not perform adequately or correctly?
ak
