(10) Technologies That Deserve To Die
W
Watson A.Name \Watt Sun - the Dark Remover\
Michael said:
Some monitors are designed for better airflow, and use parts rated
for higher temperatures. Electrolytics are rated for "X" number of hours
operating at "Y" temperature. So, the more that it is on, the more heat
damage occurs. Take a look at any of the capacitor manufacturers
websites Vishay, CDE, or dozens of others, and you will see at least
three temperature ranges: 85°C 105°C 125°C. Using a higher temperature
part extends the life of monitor, or other equipment. Also, some use
more low ESR parts, which hold up better in some applications. Some are
too cheap to use high frequency rated parts, causing more internal
heating of the electrolyte. This slowly boils away the liquid, which
causes the ESR to rise, and causes more internal heat. Finally, the
capacitor either has too high of an ESR, or the capacitance has dropped
too low to work properly.
Or probably the worst offense: locating the caps next to a heatsink or
power resistor, etc. Like poor design.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
I speak only for myself, no one else, & they're my opinions
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
S
Spehro Pefhany
There's often a trade-off between thermal and electrical design...
Best regards,
Spehro Pefhany
W
No doubt. Y'ever notice how the SMPSes have an area that seems to be
separated from the rest of the circuits, mainly because it has the
rectified AC line current on the incoming side. So the filter caps have
to isolated from the rest of the circuit. I guess the point is that the
designers are forced to place components in a certain area because of
high voltage testing requirements and the like.
Another oddity is that some SMPSes have a fan controller circuit, which
turns on the fan when it gets hot. Well, why doesn't the fan always
stay on so it _never_ gets hot? That way, the components last longer!
Yeah, sure it's noisier..
Best regards,
Spehro Pefhany
S
Spehro Pefhany
Aside from the noise, the e-caps and the fan are the two main parts
that "wear out", but yes, that's another trade-off- noise vs. life. Or
the variable-speed fans so that the life is constant no matter how
cool the environment. ;-)
Best regards,
Spehro Pefhany
C
Chuck Harris
Hi Watson,
I'll let you in on a secret: I have made thousands of dollars
fixing high end switching powersupplies, such as the Lambda's that
put out 5V, 500A. In every case, all I had to do was repack the
ball bearings on the fan motors. The bearings would gum up, and the
fans would slow, and the motor would send a fault signal to the
powersupply controller board, so the 5V would quit.
The moral of the story is the fans are the least reliable part of
any powersupply... particularily 12V DC muffin fans.
-Chuck
W
Watson A.Name - Watt Sun, Dark Remover
Hi Watson,
Yeah, they don't make them like they used to. Seems like older fans
used bearings, etc, that lasted a lot longer than today's fans. I've
seen aquirrel cage fans run for many years, maybe a decade.
We have a bunch of new Crisco switches with the dual PSes, etc. The
old 3Com fans used to gum up and a few weeks later the PSes died. I
wonder how long the new stuff is going to last.
C
Chuck Harris
The other thing that kept the older fans a running was the motors
that were grossly oversized for the job. The newer fans are part
of the powersupply efficiency rating, and are sized to be as low
power as possible. Any amount of bearing drag more than new, and
the motors slow and stop.
-Chuck
D
DarkMatter
?? What particular kind of crack are you smoking, or rather what kind of LCD
controllers are you using? I watch movies (and play games, for that matter)
on banks of LCD monitors all the time.
And all at no higher than 60Hz most likely. And they DO have a
persistence issue, whether YOU see it or not.
I suppose the newer 75Hz models might be bit better, but, I like a
good, crisp, huge CRT flat face monitor for my CAD work, as well as
for games.
D
DarkMatter
Hi Watson,
-Chuck
At least, the ones that Lambda used... Apparently.
D
DarkMatter
power as possible.
Naaah... The fans used in small environmental chambers last
virtually forever.
C
Chuck Harris
That would be so if Lambda was the only supply where I saw
12V fan problems, but it isn't. I have also run into it in the
little fans that live in PC power supplies. Only, they are
typically sleeve, rather than ball bearings.
-Chuck
L
Lewin A.R.W. Edwards
matter)
Now tell me, what kind of movie content are you obtaining that has a
framerate faster than 60Hz?
BTW, checking my monitor info, I see that I'm running at 74Hz. The physical
framerate of the LCD isn't rated, but I do not see motion artifacts of any
kind.
O
oldsoundguy
for games.
I have a 20.1" NEC with a 75 refresh rate .. no lag there .. great
for video editing!! It is a pivot, so I can use it in either
landscape or portrait orientation (which is great as is displays the
whole page when composing brochures and the like!) (software is 35
bucks to make it work) As to crisp , how does 1280 x 1024 grab ya
(default setting)
D
DarkMatter
-Chuck
There are fans, and then there are fans.
We make rack products that utilize fans and filters and they last
for years, just like a good ol' Tek scope or HP scope or analyser.
It all comes down to getting what one pays for. There are superior
brands, and even models within a brand name that is good, that get
economized, and thus fail sooner.
If Lambda bought a cheaper fan, they would have suffered for it in
field failure numbers being high. From your input, they did.
I have seen products whose fans never failed during the life span of
the product itself.
I don't economize on air handling. When fans are called for, there
is usually some heat that needs to be carried away. They, being
mechanical, need to be as reliable as possible. Brand does matter as
well.
D
DarkMatter
You don't know much about displays.
They spent ten years getting refresh rates up, and your lame ass is
thinking in the stone age if you think 60Hz is OK, particularly for
CAD or gaming.
Much less Putting up a DVD presentation, windowed.
