Hi all, been researching but ended up with more questions than answers
I bought outdoor string lights online, it's 25 LED bulbs, 24VDC. The bulbs have no markings whatsoever but it said online somewhere they are 1 watt. Where im getting confused is the power supply it came with says Prated 6 watts, there is no mention of amp output. I should mention they run perfectly fine on this supply. Just can't understand how 6 watts can drive 25x1watt bulbs.
Due to other factors I can't use this power supply, I need to buy another one, so I think I need to buy a constant current driver, I believe a 12-40VDC, 250mA will work does that sound right? And what if I got went higher ie 320mA will that burn the LEDs out?
Thanks for any help!
