Sir Hemant Choudhary . . . . .
- 1 . . . . . Also, Do you mean to say, the +3.3S is ONLY generated at this point and will not be switched unless Q201 is supplied with a signal from micro.
Here is the sourcing of both of your units
3.3 VDC MAIN and
3.3 VDC SWITCHED supplies.
FLOW THROUGH . . . .
+5VDC comes in at the top right corner via the RED line and passes to switchable IC21 which has its activation pin, 1 , being connected back to the +5VDC input, so that it permanently powers on , upon an initial +5VDC power presence.
It outputs at PINK 3.3VDC line and immediately passes upward thru L210 and provides a constant 3.3VDC main supply.
The 3.3 also immediately finds the PINK path to the left to the SOURCE of Q200 FET, where it is being open circuit over to the Drain of Q200.
Now where your once MISSING Q201 filled in, was in making a conductive C-E path for gate drive to Q200, if there was being base voltage activation via the GREEN / BLACK base path down to pin 96 of IC20 u/p. THEN the SOURCE to DRAIN conduction of Q200 has switched your 3.3 VDC SWITCHED power and outputted to the PINK / BLACK line..
- 2 . . . . . Further, the STKs pin number 123 & 8 are floating.
I initially suggested that you start with floating the power supply terminals right at the pins of the larger, and heavier taxed STK, with its additional hefty center channel.
SINCE first voltage readings initially detected a significant DC voltage presence on the protection sense sampling lines.
Therefore, that was indicative of an imbalanced voltage fault being within the power module.
Your floating them, then resulted in those sense lines, then being close to ZERO VDC, thus pointing to fault within the MAIN
STK module, and the second
STK unit . . . . . VERY likely will be good.
So you need to keep main
STK power connections floating, since, after we clear up the " Faltering Relay Syndrome ", the one good STK should give us two channels of good music, then only leaving the BIG BAD
STK to be replaced.
- 3 . . . . . But the voltage that appears across the two big capacitors is way less ie +25 and -34v than plus minus 50v.
Page 118 main power supply at the bottom of the page.
Note that
RY100 operates its separate DPDT contacts such that there is initially the AC_BL low voltage tap on the power transformer feeding into the
TOP of the
FWB rectifier.
Same is true with the other relay contact set with the transformers other AC_BL
LOW voltage tap on the other half of the transformer feeding into the
BOTTOM of the
FWB rectifier.
When a high logic level from the u/p comes into the SP_IMP at
Q1015's base it turns on companion
Q1016 to power up
RY100's coil and transition its DPDT contacts to then connecting the
top and
bottom of the
FWB to the the sets of AC_BH high taps .
THAT activated
RY100 relay then will have ramped your + and - power amp supplies up to
FULL supply voltages.
SO . . . . the unit is working off a set of power transformer low voltage taps initially, but
RY100 relay activation then connects the set of higher voltage taps of the transformer to the
FWB inputs.
- 4 . . . . . Relays being involved.
You can see and feel and measure coil voltages at / of all of the relays in the system . . . I can't.
A cluster of relays that I think that we can ignore will be the ones that disconnect the speakers, they are being .
RY341-42-43-44-45 .
Now unless I am overlooking one, the other two should be the one in the sub / standby power supply which I asked you to track down as to where its contacts are, but the coil is easily found.
The other relay is the one associated in switching transformer taps to level shift the
STK power supply up to full voltage.
When you have power on the unit and just after having pressed the power switch, one or two relays close, and after a slight pause . . . of seconds . . . in having found a circuit fault . . . . . the activating / hold power is cut off from the relay coil .
I need to know which that relay (s?) that is being. Then we continue.
RELEVANT SCHEMATIC EXPLANATION . . . . with its hot and cold running flow paths . . .
73's de Edd
