StormyWaters
- Nov 30, 2012
- 3
- Joined
- Nov 30, 2012
- Messages
- 3
I came across a 110v dc motor a friend bought for a project and ended up using a smaller motor cause this thing is huge. It has 3 wires, the wire diagram shows A1 and A2 and says its reverse-able. I guess that means armature 1 and 2 plus the 3rd green wire is a ground. I found a motor controller off ebay. I understand where to wire the input. I believe the 2 wires not the ground can be wired to the armature + or -. I get confuse for the excitation + and - tabs on my motor controller. The manual shows a curly cue (transitor?) wired to the excitation. I don't know if i should do anything with the excitation connectors or if i need to hook them up some how.
