wiring gurus. powering up the top display without stereo in 2005 acura Rl
Discussion in 'General Electronics Discussion' started by fuzzysig, Apr 20, 2017.
  1. fuzzysig
    fuzzysig
    Oct 23, 2015
    25
    I'm almost done with my indash install retaining the heater controls and nav controls
    the only thing absent is the actual cd changer unit.
    well ( big **** you goes to Honda again. for integrating what seems to be unnecessary. top display control)
    it seems to be completely powered and controlled by the cd player unit since all the wires are going from it to the top display.
    even the temperature display
    so I poked around yesterday trying to power it up without the oem cd player and had no luck
    I found the wires and tested each individual one to see if it can show the temp numbers but it doesn't as far as I know
    anyone here good with electronics can find a way to power it up?
    refer to audio system PDF from here for the wiring schematics
    http://www.acuralegendwiki.org/index.php/G4:_Service_Manuals_And_TSBs
    there are 2 wires to power the LCD backlight I got those.
    but other ones I couldn't get anything out of
    the stock cd player sends 9-10 volts to few of those wires but I don't know if they are data wires or voltage specific
    I poked them back into sockets where they go individually but nothing powers up.
    I will do more poking later but if you know how these things work . drop a line or two
    #1
    1. Advertisements
