Wiring a Finder 80.01.0.240.000 timer relay
Tony Oxford
Dec 29, 2017
Dec 29, 2017
I am attempting to wire the above timer relay. What I am trying to accomplish is using a momentary switch to activate the timer for 10 minutes. I currently have 12vDC +to A1 and -to A2 ..... not sure where to go from here.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Wire your push button between A1 and B1.
Set the switches to achieve the function that you require.
It's all in the data sheet!
Tony Oxford
Dec 29, 2017
Dec 29, 2017
I do have that wired correctly. If I want instant on and power for 10 minutes how would you recommend the settings? Where should I place the exiting power cables?
I'm not a electric tech and just trying to make this work for a little project.
Thank You......
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Set the switch to D1 and apply your power input to 15. Connect your load to 18 and adjust the bue dial for the delay period.
