P
Pigcorn
Problem: I need to know how to wire a DPDT relay:
Why:
My 2 wire heat system does not provide enough power to my 24vac home
automation Thermostats. Basically all is fine until the thermostat
calls for heat and then my zone relay uses too much power on the line
to signal the boiler and end result is that my thermostats die and
then reset and never finish the call for heat.
Solution: to my problem above is to wire in a 24vac transfomer to the
Red (power wire) of my thermostat and put it on a relay so that it
only receives 24vac when it calls for heat. Otherwise the 24vac is
constant and it heats up the thermostats and they then tell the wrong
temperature since they are heating up!
Question: I know I only need a SPDT relay for this and I am not asking
an HVAC question. That solution is already solved. What I am asking is
on my Omron MJN DPDT General Relay I have these terminals
1 3 (1/7 connected 3/9 connected)
4 6 (N\C)
7 9
A B (Coil Wire)
How do I wire this. on the thermostats the R terminal is power and the
White terminal is the trigger that calls for heat.
Any idea?
Why:
4 6 (N\C)
7 9
A B (Coil Wire)
Any idea?
