S
Serious Machining
I have a five lamp ceiling light fixture in which one particular lamp
frequently burns out while the other four lamps last for over a year's
time. The bulbs are 60 watt incandescent globe. All the lamp sockets
are wired together along with the switched 'hot' wire. Similar for the
neutral wires. Everything appears tight - bulb to socket, socket to
fixture, wires connected to socket, joining of the five lamp wires to
house wiring, house wiring to/from wall switch. I have even exchanged
bulbs among the five as well as installing new bulbs in the offending
lamp - and nothing seems to resolve the problem. If I leave the blown
bulb in the lamp, the other four continue to work just fine and last a
long time. The problem lamp generally blows when the fixture is
switched 'on'. The socket for this lamp does not get any hotter than
the others and I have never detected any arcing or smelled ozone. What
could make this lamp most susceptible to the jolt of the inrushing
voltage & current when the switch is flipped 'on' ?
- Dennis Anderson
- Dennis Anderson
