D
dhana
what is the use of composite signal generator, zero crossing detector
and comparator
and comparator
dhana said:what is the use of composite signal generator, zero crossing detector
and comparator
and comparator
and comparator
Bob said:1. Composite signal generators are used in those applications
where all-metal ones would be too heavy.
2. Zero crossing detectors are used when it is important to
recognize and/or count the number of zeroes which cross
one's path. In many cultures, having your path crossed by a
zero is analogous to our beliefs regarding a black cat crossing
your path.
PeteS said:This is important in some areas because zeroes are slippery
and can wiggle through where a one can not.
and comparator
JeffM said:.
You guys slay me.
These rate with some of my favorite respones to homework trolls:
http://groups.google.com/group/sci....9da2687c23b?q=out-*-Fields+textbook+*-megohms
http://groups.google.com/group/sci....-*-*+zz-zz+your-teacher-*-*-*+qq-qq+*-*-exist
http://groups.google.com/group/comp...ineers-that-did-their-own-homework-in-college
A previous one from Pete:
http://groups.google.com/group/sci....eally-mean+insert-task-here+*-having-to-think
Now that the accounting industry has oversight,
http://www.google.com/search?q=Arthur-Anderson+Enron+Sarbanes-Oxley
it appears the lazy, corner-cutters are trying to find other fields.
PeteS said:I had been considering writing an authoritive guide on 'How to post your
homework questions to s.e.b and s.e.d', but I never got past the first
paragraph as I kept snorting my wine on the keyboard.
Now there is the possibility I could write such a thing while not
drinking wine, but that would remove any real point
Cheers
PeteS
and comparator
I believe that is the correct answer, since I was thinking of posting
an almost identical reply.
Michael
feebo said:a zero crossing detect circuit is...
feebo said:but this is a "basics" NG
When you subsidize a behavior, you get more of it.
If the OP is too lazy to pay attention in class or to learn to use
Google,
a failing grade is apt.
Please don't feed the homework trolls.
Michael said:We need a real, nice "Homework helper FAQ" for the sci.electronics.*
newsgroups. Maybe we could all use up lots of puns before they go
stale? ;-)
feebo said:I hear what you are saying Jeff, and while I do agree that this is
probably someones homework I chose to give the benefit of the doubt.
Certainly if this had been posted anywhere but SEB I would have
ignored it.
I'll try to be a bit more discerning in the future but I remember what
a mystery it all was (and a lot still is) all those years ago - I
couldn't even find someone to tell me how the pins on a transistor
related to the connections inside the circle (which was the emitter) !
so much water under the bridge since then )
PeteS said:I was thinking on the lines of a non-FAQ (mild sarcasm mode) thus:
Title: The title of your question is all important. To get the attention
of the people who can answer your question, you need to make it stand
out. Known methods of doing this:
1. USE ALL CAPS
2. Reference a current political problem
3. Ensure it is indecipherably vague.
4. Use 733t 5p34k, or txt spk
Examples:
WHY DOES THIS IC RESET ALL THE TIME?
Are Republicans to blame for my project?
Confubulator fries?
Cn U Hlp wth prblm?
and so forth
and then perhaps a serious (well, mildly serious) one afterwards that
gives real guidance. Make it through the first part and one is rewarded
Cheers
PeteS
PeteS said:I think what JeffM (and myself) are saying is we help those who have
tried to help themselves
I will definitely help with homework *provided the OP has tried to solve
the problem already* and is perhaps stuck on phraseologu or perhaps a
somewhat murky chapter in a text.
To paraphrase, _We help those who help themselves_
Michael said:All the others are to proceed to the closest fast food place to apply
for their job in their lifelong career in the food service industry.
