Why are SCR's recommended for inductive loads (and not Triacs)?
Hilton
Nov 16, 2018
3
Nov 16, 2018
3
I have read that SCR's are recommended for inductive loads, while Triacs are not. Can anyone explain why this is so?
Harald Kapp
13,722
13,722
On EEVBlog one quote is:
There is no reason to use dual scr, a single snubberless triac can do the same job with the same reliability and is easier to trigger than dual scr's.
Omron states:
Thyristors connected back-to-back or a triac can be used for Solid-state Relay switching elements.
Unless you experience very high dv/dt a triac should be perfectly useable.
Hilton
Nov 16, 2018
3
Nov 16, 2018
3
Great thanks. I will give it a try. This may have been an outdated recommendation.
