Hi John,
I'm currently working on a HV driver for an optoelectronic device, as
a spare-time project for a friend who's trying to start up a business
around his new e-o effect. I did one version a while back using a tiny
pot-core stepup transformer (a real pain to wind) and a 4-stage C-W
using four of the MMBD2004 dual diodes. That worked pretty well (got
900v from 5v in); I deliberately loaded it to speed up the discharge
time constant - the HV controls optical attenuation, and we need
control speed - so it wasn't very efficient. I'm going to do another
generation, using a stock center-tapped surface-mount torroid as a
flyback-autotransformer sort of thing, driving two 3-stage C-W
thingies, one for + and one for -, shooting for 1200-1400 volts total
between supplies. The bipolar thing avoids some breakdown issues in
the e-o package.
WOW, I'm willing to bet that your opto-related power supply is a near
perfect ap for the piezo device!!!!! These things excel at moderate to
high resistance load currents!
Before starting, please keep an eye peeled on the TI website. They are
going to release a new driver chip any day now. It's a 20 pin chip,
however it has lower power consumption and much more flexibility than
the present 8 pin drivers. It should be possible to convert the chip
from a constant current source to a constant voltage source.
My control circuit is a sot-23 micropower opamp as the error sensor, a
sot-23 "tiny logic" schmitt trigger as the oscillator/duty cycle
generator/fet driver, and a small n-channel mosfet to drive the
inductor.
If the piezo works as well as you suggest, that might be interesting
too. Got any links to parts?
There is a wealth of technical info on the web, but there are few
suppliers of actual parts. In the US, there is only one vendor for the
actual parts. NO ONE MAKES A LOW POWER UNIT, they are all in the 2-6
watt output range.
CTS used to make them, the are out of the piezotransformer market now.
Steminc in Florida makes them, but refused to answer questions about
availability and second sourceing. They have been selling them on
EBAY. They are presently shut down for vacation till th e5th of
January.
As far as other vendors, there are quite a few. But, they seem to be
all Asian and Digikey doesn't carry these devices from any of the
manufacturers! They are going into Asian contract manufacturing houses
I think:>:
Anyway, the Asian vendors are Panasonic, Fuji and a Korean company. I
forget the anme of the Korean vendor. NEC/Tokin and Tamura make
complete convertes based on PZT's. Another one is Hitachi. Piezo
Systems Inc (MA) are interested in PZT's and might make them someday.
Hope this helps. I have about 10 MB of misc technical docs, spec
sheets and various related items. I'm happy to email this stuff to you
if you like.
If you only want a primer, the 1999 EDN article on these devices is a
good start, let me know and I'll email the PDF to you and you can
decide if you want to look further>:>
Be warned however, driving these little buggers ain't easy. Although
they have Q's from 500 to 1500 and should oscillate, they don't work
well in a power oscillator circuit:>: There are mode changes that are
load dependent, th emechanical resonance and the electric resonance
frequencies are different and you can't run them without load-they
easily go to 10KV output without a load and the crystal is fractured.
Driving them with a VCO and having the output voltage determine the
vco's frequencyt is the way to go......when driven slightly off
resonance, they do not draw much power since they look like a series
resonant circuit.
Anyway, have fun:>:
Regards,
Al
