What's this part?????
Discussion in 'Datasheets, Manuals and Component Identification' started by LectricCircuit, Apr 21, 2017.
  1. LectricCircuit
    LectricCircuit
    Apr 7, 2017
    33
    There is what looks like an Allen screw that goes in the hole on the top of the part but it's got a flat head top instead of a hexagon top for Allen key. It comes all the way out. Inside is not threaded but has metal notches on the plastic and as u thread the screw in it goes down one notch with each full turn of the screw I'm assuming. There's 6 pins total. Two pins are connected to the part housing so I know those are ground but idk what the other 4 pins are. I was thinking maybe some sort of potentiometer but I'm not sure. Any info would be appreciated. Not a great camera so I can't get pic of inside where the metal notches are but I'll get whatever I can. Only thing on the part is on the one side and it says V053 and then right below that it says G98-
    Also if you know the specs of whatever it is or a link to the datasheet that would help a lot. Thank you.
    #1
    1. Advertisements
  2. LectricCircuit
    Bluejets
    Oct 5, 2014
    2,389
    467
    Tuning coil.
    Bluejets, Apr 21, 2017
    #2
    1. Advertisements
  3. LectricCircuit
    davenn Moderator
    12,545
    1,546
    Sydney, Australia
    it's a ferrite core .... they are quite brittle and easily snap if too forceful trying to turn them
    I can pretty much guarantee they WILL NOT be metal notches as that would totally mess up the tuning. The notches will part of the inner surface of the plastic former that the wire windings are on.
    no not a pot ... it isn't a resistor ... there will be 1 or 2 coils that are mutually coupled by the ferrite core that you removed
    they may be a generic part and discoverable ... but possibly more likely a specialist part for a manufacturer
    davenn, Apr 21, 2017
    #3
    hevans1944 likes this.
    1. Advertisements
