S
[email protected]
I found that same input signal of the ic require the dc-couple. what
the mean of dc-couple? pls advice..
John said:Vcc
Mean of DC couple = -----
tokohanz said:thanks for your advice.
it means that IC pin mention 'dc-coupled' allows the Vcc/2 dc flows to
the pin? that have any window of the dc if my dc is not same for few
samples?
DC coupled means the frequency response will go down to DC.I found that same input signal of the ic require the dc-couple. what
DC coupling would be mandatory if you have an amplifier to power say a DCCharles Schuler said:dc coupling is with a direct path or a component that allows dc flow, such
as a resistor.
ac coupling is with a capacitor or a transformer (only ac signals are
coupled)
I'd expect better use of English from someone in Singapore.
To be honest - if you *need to ask* it means you haven't understood
something *really basic*. I suggest more study and listen to the
lecturer properly.
Independent study may also prove helpful. Google is your friend.
Graham
Spehro said:He or she could be a foreign student- but how do you figure Singapore?
I see Queensland in Oz.
