LegitimateOG
- May 25, 2018
- 2
- Joined
- May 25, 2018
- Messages
- 2
What i need to do is transmit x, y, z data from an accelerometer to a serial to usb converter, which will be connected to a pc.
I plan to have more than 10 accelerometers connected in this fashion to the pc, so capacity for this is necessary.
The purpose of the accelerometers is to track human body movement.
Smaller is better.
I plan to power via 3.3v AA battery pack on accelerometer side, and usb (which I believe will be dropped to 3.3v) on the other side.
I believe the communication can be one-way as no data needs to be transmitted to the accelerometer.
I want the data transfer rate fast enough that any delay between reading from one accelerometer to the rest is not noticeable to humans.
This device will be packaged in with the product I plan to sell, therefore isolating the channels of communication is important.
This is the accelerometer I am using currently: https://www.sparkfun.com/products/9269
If there is a solution that can transmit and receive right out of the box, that would be preferred.
I am open to changing any of my current equipment if you know of a set that works together.
Smaller is better.
