M
mike
I have a Canon PC25 photocopy machine I'd like to patch up.
The rubber roller in the paper path has turned
to mush. I cleaned it off and replaced the
rubber part with a stack of O-rings.
Problem now is that the OPC drum has rubber
residue on it. That ruins the copy at the edge.
What can I clean it with?
I've used isopropyl alcohol in the past, but I
remember that some of the drums won't stand
for that.
What can I use to clean the drum on this Canon PC25?
There's a second roller down the chain that's also
very soft. It's still holding it's shape. Is there
anything I can put on it to harden it? I'd put O-rings on
it too, but I can't get access without major disassembly.
I'd just change the rollers, but they're integral
with the gear and maybe even the whole assembly...and it's
underneath a lot of other stuff.
I tried pulling the roller/gear off the axle and it won't
come. Major disassembly required to get it out where I
can work on it.
Suggestions for a quick and dirty fix for a copier that
does maybe 30 copies a year?
roller pix:
http://nm7u.tripod.com/r1.jpg
http://nm7u.tripod.com/r2.jpg
Thanks, mike
return address is good, don't change it.
400cc Dirt Bike 2003 miles $495
Police Scanner, Color LCD overhead projector
Tek 2465 $800, ham radio, 30pS pulser
for that.
can work on it.
roller pix:
Thanks, mike
