what size load capacitor for crystal oscillator?
mike wax
Oct 10, 2016
34
Oct 10, 2016
34
OK so i have a homemade PCB, a uC, and an 8MHz crystal. According to the common formula, CL = (C1 * C2) / (C1 + C2) + Cstray. CL is supposed to be 18pF.
simple enough except for Cstray. most articles i've read say that Cstray is probably between 3 & 5 pF. is this a reasonable figure?
Here are some pics of my board, a standard FR4 with 1oz. copper. pardon the lousy camera:
davenn
14,264
14,264
so, did you google the datasheet for the chip ?
it will have component options​
mike wax
Oct 10, 2016
34
Oct 10, 2016
34
I said the chip, not the crystal, tho the crystal datasheet does give indications of the value
oh... yeah that's a good idea, hold on.... yes it does have a suggested circuit:
so yeah if i could figure out that Rext. i guess i'd have to either scope it or find some kind of timing routine to measure it. but then i can't get a resistor with some specific precise value.
7,682
7,682
The capacitance is not critical. Use 27 or 33pF.
mike wax
Oct 10, 2016
34
Oct 10, 2016
34
well i wouldn't even use a crystal except it's supposed to be necessary for the frequency of the USB interface. so a pair of 33s is good enough for that?
7,682
7,682
Yes. Changing the temperature would have more effect than the capacitors being off by a little bit.
