Sir Joebrad27 . . . . .
Dammmmmmn . . . . Joe . . . . you rated a reply from both EINSTEIN and 'ole Numb-nutz here . . . .
I am not particularly seeing 3A principal power devices on that board, with the sole two heaviest discrete power items being the two metal film resistors , one of which is connected back to the illumination medium of the lighting source internal to the switch. The main adjustment pot is being a 100k . . .which is somewhat upwards from what we would typically see being associated with a power supply.
We confirm that this of circa 1996-1997 vintage, with this actual design evolvement being related to earlier times.
At the terminal blocks we see the N N1 L2 L1 assignments . . . soooooooo in case this unit does get AC line connected, I could see 1 of the 5 polyester white block and a power resistor serving as an AC dropper function to feed to a Zener to get a low voltage power supply associated with the 5 small signal semis in the rear. BUT I see no filter capacitors of any size excepting the two lilliputian sized small black units. (What are their cap values and voltage ratings ?)
They did seem to have placed a power switch and a fuse that is probably greater than THIS particular board justifies UNLESS they are switching and looping the switched output to a larger power related associative assembly in additional to somelow level info at the L and E terminals.
(Can you now further confirm, that there are no POWER FETS --BIPOLARS—FETs –SCRs or TRIACS sandwiched between the PCB and using the alum-nin-ninny-yum-yum front panel as a heat sink ? )
The rolling out the door / or/ ready for sale . . . final sticker . . .suggests this being at the 17th week of 1999.
The best identifier of the board proper would be the boards silk screening of the identifier
BP (Band Pass ? )3 ~??SEL
Issue 4
Feb 96
With the particular interest on the
BP3 ~ ?? (Blue wire blocks out)SEL
I could see this board more frequency or filter related than anything else .
73’s de Edd
