What is the purspose of pre-tinned wire?
K
krw
Yes and unless and until a crime has been committed, which it hasn't,
you can all **** off and die.
Yes, Roy. We know you're off your meds, again.
B
Bob Larter
msg said:
Michael A. Terrell wrote:
<snip>
I have no knowledge of these particular posters or their ISPs but I caution
readers not to assume that identical NNTP-Posting-Host addresses
automatically
mean the same user; some small ISPs assign RFC 1918 addresses to clients
and have a small block of public IPs exposed to the 'Net.
That isn't an RFC-1918 address. It belongs to Cox Communications, Inc.
Also, a public
access machine or a shared machine in a residence may conceivably be used
by different posters.
True, but DimBulb is infamous for sock-puppetry.
B
Bob Larter
<http://ww2.cox.com/aboutus/policies.cox>
Acceptable Use Policy
Prohibited Activities. You may not use the Service in a manner that
violates any applicable local, state, federal or international law,
order or regulation. Additionally, You may not use the Service to:
*Conduct, participate in, or otherwise facilitate pyramid or other
illegal soliciting schemes.
*Take part in any fraudulent activities, including impersonating
any person or entity or forging anyone else's digital or manual signature.
*Invade another person's privacy, stalk, harass, or otherwise
violate the rights of others.
*Post, transmit, or disseminate content that is illegal,
threatening, abusive, libelous, slanderous, defamatory, promotes
violence, or is otherwise offensive or objectionable.
S
Spike
If there's a verb to use to refer specifically to turning an element
into its oxide, to eliminate confusion with the generalized oxidation
process, please let me know what it is
I used to use the terms 'oxidised' to refer to the production of the
oxide, and 'oxidation product' for the general case other than
oxides.. Context should anyway make it clear which is which.
R
Rich Grise
Silver does not oxidize so much as it tarnishes, by picking up sulfur from
the air.
I once watched a guy build a 1KW linear out of surplus parts. He had this
beautiful silver-plated tank coil, and this idiot SAMDPAPERED the tarnish
off!
Can you say "skin effect", boys and girls? ;-)
Cheers!
Rich
S
Yes, fuckhead. Now show me a state or federal statute, you stupid ****.
Then go back and read what I said.
Cox will send you information about using your filters.
If I were to commit a crime, they would forward any pertinent
information on to whichever authority necessary.
Until a crime is committed, idiots like you can **** off and die.
You got that, you stupid ****?
I find you retarded bastards offensive and objectionable.
That makes my case as strong, if not stronger than you your retarded
case.
No go find something real to involve yourselves in, you petty little
E-1 grade bastards.
S
W
. | ,. w , "Some people are alive only because
\|/ \|/ it is illegal to kill them." Perna condita delenda est
This is the only thing that keeps retarded fucks like you alive.
A
Archimedes' Lever
Not Roy, dumbfuck krw. You are so demented that you have forgotten how
to track the people that you attack. Typical troll retardation.
D
Dr. Heywood R. Floyd
off!
Cheers!
Rich
It could have been solid Silver.
Also, Silver plated wire DOES have favorable skin effect, sanded or
not. Tarnished Silver wire would not be as favorable.
Can you say get a grip on what skin effect is?
The coil will do the job it is designed for in either case.
K
krw
Yes, Roy. We know you're off your meds.
No, Roy. I've not forgotten you.
B
Bob Larter
msg said:
Indeed, and I don't expect a large operator like Cox to do it, but some
ISPs
NAT their clients with RFC-1918 addresses, all of which translate to a
single
public IP, ergo, many NNTP users may all originate from a single IP.
True, but it's quite rare at ISPs. NATing is usually done in businesses,
rather than at ISPs.
B
Bob Larter
You think your impotent threats bother anyone DimBulb?
S
It takes a true retard like you to imagine that such a remark is a
threat, when it was obviously merely a statement of fact.
You are only one of the impotent, retarded dipshits in this group,
Larter. Your mommy is calling, bobby. Run home now, retard boy.
B
Bob Larter
Go **** yourself, DimBulb.
R
Rich Grise
Ever heard of "surface area"?
At 100% of its original efficiancy?
Rich
K
krw
**** off, KeithTard.
If I've told you one, I've told you a thousand times. You are not my
type. If you're that hard up go raid your mommy's hamper again.
S
W
Siad the total retard with the totally retarded and immature sig for
all to see. That places your mental age at no more than 14, you retarded
BlownBulb dumbfuck.
S
From time to time (for many years now) I deal with issues involving H.323
and RTP connectivity (payload contains IP information) and I am always
surprised by the number of ISPs I encounter that NAT their clients. These
are mostly small operators and often rural. I too run a neighborhood WISP
that NATs the clients, many of whom use the same O/S and NNTP user agents,
and I would be quite distressed if newsgroup readers assumed that IP
addresses and message headers uniquely identify the poster who just happened
to be a neighbor and not myself.
Michael
The idiot that made the remark that "many NNTP users may all originate
from a single IP" is about as dumb as it gets.
For one thing, they are required by law to uniquely ID ALL of their
subscribers.
So to that idiotic asswipe... show us an example of your "several
users, same IP" claim, jerk.
D
Him abrading the less than 1/10th of one mil tarnish off with an
abrasive does NOT reduce the size of the wire by ANY amount that would be
measurable in the setting it was being used in.
At most "hand made radio" frequencies... yes. And the term is
efficiency. It comes from the word efficient. There is no word
"efficiant".
