What If The CD Player Doesn't LIKE The Disc?
E
EADGBE
More CD player shenanigans....
I still haven't gotten round to measuring the voltages in the Audio
Alchemy CD player...but I promise to do so soon!
But in the meantime, I have another question, about another CD
player...
I have a Magnavox CDB650 that I purchased new back in the 1980's.
In all this time, it has never given me any problem (touch wood).
I recently purchased a new CD that the Magnavox player WILL NOT
recognize. When I insert the CD into the player, it spins for a
moment, and then the "Error" light comes on.
This is the ONLY disc I own that this Magnavox won't recognize. It's
as if the player doesn't like the disc or something.
This is NOT a CD-R disc. It is a brand new, mint condition, store-
bought disc. It is also NOT a disc with any multimedia content on
it. It is nothing more than a normal, regular CD.
All of my other CD players have no problem playing this disc.
While I'm at it, there is another disc that is a bit weird when
inserted into the Magnavox. I have a copy of Nat King Cole's "Just
One Of Those Things" -- one of his lesser-known albums.
The disc plays fine in the Magnavox, but through the window you can
see the disc spinning VERY crooked. It is not level at all. Why
would this happen? Believe it or not, the Magnavox plays it just
fine, with no skipping or any other problems.
By the way, the disc that the Magnavox refuses to play spins perfectly
flat. No vibration at all.
A
Arfa Daily
geoff said:
I'd say the CD player doesn't like the disc then.
The disc may be faulty in a way that matters to that player , but possibly
not others. You get that...
geoff
I'll second all that the others above have said, and agree with Geoff here.
It's not at all unusual to see players that simply won't play - or have a
lot of trouble playing - just one or two discs out of an owner's collection.
I have had them send in players for repair with an example disc, and they
are quite right, it won't play it, and of course, they have always "tried
the disc in the neighbour's machine, and it's fine !"
But if the player is trouble free with every other disc that you - and
they - put in it, including 'official' test discs with deliberate errors for
checking servo performance etc, what can you do ? You can never see anything
wrong with the eye pattern on such players, and I've even tried replacement
lasers, without altering the symptoms a jot, so I think that it must be a
case of too many errors for the player to correct, but who can tell ...
As you surmise, and Geoff says, the CD player just doesn't like the disc
then :)
You know, I've just had a thought. Long long time ago, I had a Pioneer that
had playability problems just on certain discs. It's very very rare for
Pioneers to suffer a bad laser, and the early ones are unpleasant to replace
because of the diffraction grid adjustment that has to be done. I was loathe
to suspect the laser, so I gave Pioneer Technical a call.
In those days, they had the best guys in Tech Support that you could ever
wish for (they're actually still there, but a lot more difficult to get to
talk to now). Anyways, I asked them about this problem, and they pointed me
at the rubber deck suspensions, saying that the problem was caused by age,
and them having collapsed some. As you might imagine, I was sceptical about
this, but I ordered a set and fitted them, and lo! it cured it completely.
I can only assume that with little or no suspension left, if a slightly
eccentric or off balance disc was put in, instead of the whole deck being
able to freely 'wobble', with the deck touching the sub-chassis, vibration
was instead transferred to the lens suspension, making this vibrate at high
speed.
Given the age of the player in question, might be worth a look at ??
Arfa
M
Mark D. Zacharias
here. It's not at all unusual to see players that simply won't play - or
have a lot of trouble playing - just one or two discs out of an owner's
collection. I have had them send in players for repair with an example
disc, and they are quite right, it won't play it, and of course, they have
always "tried the disc in the neighbour's machine, and it's fine !"
for checking servo performance etc, what can you do ? You can never see
anything wrong with the eye pattern on such players, and I've even tried
replacement lasers, without altering the symptoms a jot, so I think that
it must be a case of too many errors for the player to correct, but who
can tell ...
then :)
that had playability problems just on certain discs. It's very very rare
for Pioneers to suffer a bad laser, and the early ones are unpleasant to
replace because of the diffraction grid adjustment that has to be done. I
was loathe to suspect the laser, so I gave Pioneer Technical a call.
me at the rubber deck suspensions, saying that the problem was caused by
age, and them having collapsed some. As you might imagine, I was sceptical
about this, but I ordered a set and fitted them, and lo! it cured it
completely. I can only assume that with little or no suspension left, if a
slightly eccentric or off balance disc was put in, instead of the whole
deck being able to freely 'wobble', with the deck touching the
sub-chassis, vibration was instead transferred to the lens suspension,
making this vibrate at high speed.
Arfa
Hi, Geoff!
The problem with the insulators was just that the disc would "barely" scrape
while trying to play. It was indeed a common problem; replaced many of them.
Sometimes the drive IC would even brown the circuit board as a result.
To the OP regarding the one disc that would not play: try cleaning the disc
itself - sometimes that helps - or perhaps the store you bought it from
would let you try another copy.
As another poster suggested, cleaning the laser lens is certainly worth a
try.
Magnavox (Philips) players were sometimes picky about discs, with nothing
that could really be done about it. When people would complain, the standard
response was, "the disc is out-of-spec, not our problem". A good example of
this was the CD-63 series having problems with discs longer than 74 minutes.
Mark Z.
M
Mike S.
Hi, Geoff!
try.
Yep. I have one from that series, and it chokes on many extended-length
pressed CD's. There's a place in Connecticut that can modify the pickup
circuit to handle off-spec discs better, but then CD-R playback suffers.
E
EADGBE
Thanks, as usual, for all the great info so far.
I forgot to mention that I did try cleaning the laser lens. I used
91% isopropyl alcohol, which usually works pretty well, unless there
is a better method that I don't know about.
F
Franc Zabkar
player...
Whenever I have compatibility problems like this, I burn a copy of the
disc. The copy usually plays flawlessly. If it doesn't, then I'd
suspect something is wrong with the contents of the disc, perhaps copy
protection as mentioned elsewhere. Is it possible that older players
can't handle CDs with combined audio and data, and is your CD one of
these?
- Franc Zabkar
T
Tim
these?
- Franc Zabkar
I would ask how large the data is on it. Some players cannot handle a
disc with more than 80 mins of audio on it. Some have a problem with
more than 74 mins. I have a factory Madonna CD that is 74:30 and it will
not play in one of my players, but it is fine in all the others. Audio
CDs can contain up to 99 minutes of data (874MB), but they have to be
carefully written at a very low speed.
- Tim -
F
Franc Zabkar
- Tim -
I have an old Philips/Marantz player that won't play 80 min CDs. As
for wobble, ISTR I once played a CD that was either recorded
eccentrically, or was not clamped centrally. The player's voice coil
positioner visibly wobbled from side to side but tracked the disc
perfectly.
- Franc Zabkar
S
Samuel M. Goldwasser
Should be adeqate, and if there was no obvious change one way or the
other, the lens was probably clean enough.
sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
A
Arfa Daily
IPA is fine, although 'electronics grade' is usually a little purer than
that at 99.7%
Arfa
