paulmackie
- Jan 9, 2014
- 8
- Joined
- Jan 9, 2014
- Messages
- 8
I just fitted HID lights to my car, the DRL circuit is putting out 9 volts, which is bringing on the high beam of my headlights (the DRLs used to activate my high beam headlight at a reduced voltage of 9 volts-now the 9 volts activates the high beam HID relay).
What I would like to do is stop the 9 volts going to the high beam headlights and tap off the wiring before whatever is stopping the 9 volts with a relay that will bring on my fog lights as the DRLs and allow 12 volts to pass when I need headlight high beams.
As far as I know, here in Canada DRLs have to be on by law.
The DRLs come on automatically when the car is put into drive.
Basically I just need the headlights to come on low beam instead of the DRLs high beam, or stop the voltage going to the high beam and wire in a relay that brings on the fogs as the DRLs.
Thanks for any help with this
