What component is this?
Discussion in 'Datasheets, Manuals and Component Identification' started by matchy, Nov 14, 2016.
  1. matchy
    matchy
    Nov 10, 2016
    Hi Guys,
    Couldn't identify what component this is. Is the shape meant to be like this? Found this in a TV Power Supply Circuit.
    Thanks.
    #1
    1. Advertisements
  2. matchy
    23,510
    2,176
    It's an inductor.
    (*steve*), Nov 14, 2016
    #2
    1. Advertisements
  3. matchy
    73's de Edd
    Aug 21, 2015
    1,990
    640
    Texas
    A continuance . . . . . .
    Moreover it is being a faster switching, high current inductor, of ~4.7 uh inductive value.
    If pulling the heat shrink covering for inspection, you would find the windings nestled down
    within a " dumbell " ferrite core.
    For enhancement of its magnetic coercivity-efficiency- Q, there is being a strong ceramic button
    magnet bonded on its far end.
    If this was found in an older CRT based television / monitor I would more likely suspect this to be
    utilized in the systems horizontal deflection circuitry, RATHER THAN in its power supply circuitry.
    73's de Edd
    73's de Edd, Nov 14, 2016
    #3
  4. matchy
    BuckeyeHam
    Dec 22, 2016
    3
    Full-Time RVer (from Dayton OH)
    The PS is likely a switching supply (by itself) or the inductor could be in a "switching regulator" portion of the PS. Texas Instruments has a whole series of Power Management devices that utilize switching methods.
    73 de Buckeye Ham
    BuckeyeHam, Dec 23, 2016
    #4
  5. matchy
    tedstruk
    Jan 7, 2012
    430
    7
    Toledo Washington
    Thats a ROHS. name means its a time trial and component thats designed to do its job correctly and with a certain amount of stability and proper functioning.
    most ROHS are specially designed to meet ROHS specs. like a ROHS designed for a heavy wire system will be designed for that enviroment, but if you used a different ROHS of the same size designed for a light wire system, it would probably fry out.
    tedstruk, Jan 8, 2017
    #5
  6. matchy
    davenn Moderator
    12,361
    1,494
    Sydney, Australia
    more bad/incorrect advice
    you need to read up on what RoHS means
    davenn, Jan 8, 2017
    #6
    (*steve*) likes this.
  7. matchy
    Pyramid
    Jan 17, 2017
    24
    5
    Steve is correct. It is an inductor.
    Pyramid, Jan 17, 2017
    #7
    1. Advertisements
