Frederic Philips
- Nov 16, 2015
- 1
- Joined
- Nov 16, 2015
- Messages
- 1
Hi guys,
So I am trying to get measurements from the MPU-9150 sensor from Invensense using the Intel Edison. I am able to communicate with the sensor and the values seem sensible.
But after a specific number of cycles, I measure only a zero from all data registers. This error is repeatable: When I try to read the Accelerometer and Gyro data(6 data registers), the data stream stops exactly at 84 cycles. If I try to read jus the Accelerometer values, it stops at double the no. of cycles i.e. 168. I sense some data is overflowing, but couldn't figure out yet.
Looking for your reply and Thanks!
Cheers,
Frederic
Code:
MPU9150.h
MPU9150.c
Console Screenshot:
Reference:
MPU-9150 Product Specification: http://43zrtwysvxb2gf29r5o0athu.wpengine.netdna-cdn.com/wp-content/uploads/2015/02/MPU-9150-Datasheet.pdf
MPU-9150 Register Map: http://43zrtwysvxb2gf29r5o0athu.wpe...ent/uploads/2015/02/MPU-9150-Register-Map.pdf
Cheers,
Frederic
Code:
MPU9150.h
- //Self Test registers R/W
- #define SELF_TEST_X 0x0D
- #define SELF_TEST_Y 0x0E
- #define SELF_TEST_Z 0x0F
- #define SELF_TEST_A 0x0A
- //Configuration Registers
- #define SMPRT_DIV 0x19 //Sample Rate Divider
- #define CONFIG 0x1A //FSYNC & DLPF config
- #define GYRO_CONFIG 0x1B //Self-Test & Scale select
- #define ACCEL_CONFIG 0x1C //Self-Test & Scale select
- //Interrupt Registers
- #define INT_ENABLE 0x38
- #define INT_STATUS 0x3A
- //Accelerometer Measurement Registers
- #define ACCEL_XOUT_H 0x3B
- #define ACCEL_XOUT_L 0x3C
- #define ACCEL_YOUT_H 0x3D
- #define ACCEL_YOUT_L 0x3E
- #define ACCEL_ZOUT_H 0x3F
- #define ACCEL_ZOUT_L 0x40
- //Temperature Measurement Registers
- //Temperature in degrees C = (TEMP_OUT Register Value as a signed quantity)/340 + 35
- #define TEMP_OUT_H 0x41
- #define TEMP_OUT_L 0x42
- //Gyroscope Measurement Registers
- #define GYRO_XOUT_H 0x43
- #define GYRO_XOUT_L 0x44
- #define GYRO_YOUT_H 0x45
- #define GYRO_YOUT_L 0x46
- #define GYRO_ZOUT_H 0x47
- #define GYRO_ZOUT_L 0x48
- //Power Management Registers
- #define PWR_MGMT_1 0x6B
- #define PWR_MGMT_2 0x6C
- //Device i.d. Register
- #define WHO_AM_I 0x75
- R1 - 0x69
- R2 - 0x68
- #define MPU_ADDR 0x68
- //Reset the Registers and Power
- #define PWR_RESET 0x80
- #define DEVICE_ON 0x00
- //Accelerometer Scale
- #define ACCEL_2G 0x00
- #define ACCEL_4G 0x08
- #define ACCEL_8G 0x10
- #define ACCEL_16G 0x18
- //Gyroscope Scale
- #define GYRO_250 0x00
- #define GYRO_500 0x08
- #define GYRO_1000 0x10
- #define GYRO_2000 0x18
- #define SAMPLE_RATE 0x00
- #define DLPF_CFG 0x01
MPU9150.c
- #include <stdio.h>
- #include <stdlib.h>
- #include <signal.h>
- #include "mraa.h"
- #include "MPU9150.h"
- void MPU9150_I2C_Init(void);
- void MPU9150_I2C_Config(void);
- void MPU9150_I2C_Write(uint8_t address, uint8_t value);
- void MPU9150_I2C_Read(uint8_t address, uint8_t *value);
- int16_t MPU9150_Get_Measurement(uint8_t addrL, uint8_t addrH);
- void sig_handler(int signum);
- sig_atomic_tvolatile isrunning = 1;
- //Acceleometer Measurement Storage Variables
- int16_t Accel_X = 0;
- int16_t Accel_Y = 0;
- int16_t Accel_Z = 0;
- //Gyroscope Measurement Storage Variables
- int16_t Gyro_X = 0;
- int16_t Gyro_Y = 0;
- int16_t Gyro_Z = 0;
- //Temperature Measurement Storage Variable
- float Temperature = 0;
- //Variable to Store LOW and HIGH Register values
- uint8_t Measurement_L = 0;
- uint8_t Measurement_H = 0;
- int main(int argc, char **argv)
- printf("--------------------------------------------------\n");
- printf("------------------eGlove Project------------------\n");
- sleep(1); //1s delay
- signal(SIGINT, &sig_handler);
- usleep(1000); //1ms delay
- MPU9150_I2C_Init();
- MPU9150_I2C_Config();
- while(isrunning)
- //Get Accelerometer Measurements
- Accel_X = MPU9150_Get_Measurement(ACCEL_XOUT_L, ACCEL_XOUT_H);
- Accel_Y = MPU9150_Get_Measurement(ACCEL_YOUT_L, ACCEL_YOUT_H);
- Accel_Z = MPU9150_Get_Measurement(ACCEL_ZOUT_L, ACCEL_ZOUT_H);
- //Get Gyroscope Measurements
- Gyro_X = MPU9150_Get_Measurement(GYRO_XOUT_L, GYRO_XOUT_H);
- Gyro_Y = MPU9150_Get_Measurement(GYRO_YOUT_L, GYRO_YOUT_H);
- Gyro_Z = MPU9150_Get_Measurement(GYRO_ZOUT_L, GYRO_ZOUT_H);
- //Print Accelerometer Values
- printf("Accelerometer:\n X:%d\n Y:%d\n Z:%d\n ", Accel_X, Accel_Y, Accel_Z);
- //Print Gyroscope Values
- printf("Gyroscope:\n X:%d\n Y:%d\n Z:%d\n ", Gyro_X, Gyro_Y,Gyro_Z);
- //Sample Readings every second
- return MRAA_SUCCESS;
- mraa_init();
- mraa_i2c_context mpu9150_i2c;
- mpu9150_i2c = mraa_i2c_init(1);
- if (mpu9150_i2c == NULL)
- printf("MPU9150 I2C initialization failed, exit...\n");
- exit(1);
- printf("MPU9150 I2C initialized successfully\n");
- mraa_i2c_address(mpu9150_i2c, MPU_ADDR);
- printf("MPU9150 I2C Address set to 0x%x\n", MPU_ADDR);
- //Reset all the Registers
- MPU9150_I2C_Write(PWR_MGMT_1, PWR_RESET);
- printf("MPU9150 Reset\n");
- MPU9150_I2C_Write(PWR_MGMT_1, DEVICE_ON);
- printf("MPU9150 Switched ON\n");
- uint8_t data = mraa_i2c_read_byte_data(mpu9150_i2c, WHO_AM_I);
- printf("Who am I: 0x%x\n", data);
- MPU9150_I2C_Write(SMPRT_DIV, SAMPLE_RATE);
- MPU9150_I2C_Write(CONFIG, DLPF_CFG);
- //Set the Gyroscope Scale to 250°/s
- MPU9150_I2C_Write(GYRO_CONFIG, GYRO_500);
- //Set the Accelerometer Scale to 2G
- MPU9150_I2C_Write(ACCEL_CONFIG, ACCEL_2G);
- printf("Initialization Complete: All Systems are GO!!!\n");
- //Set MPU Device Address
- //Write Command and Data
- mraa_i2c_write_byte_data(mpu9150_i2c, value, address);
- //Set ALS Device Address
- //Write Command and Read Data
- *value = mraa_i2c_read_byte_data(mpu9150_i2c, address);
- //Read & Store the Lower Byte
- MPU9150_I2C_Read(addrL, &Measurement_L);
- //Read & Store the Higher Byte
- MPU9150_I2C_Read(addrH, &Measurement_H);
- return (int16_t)((Measurement_H << 8) + Measurement_L);
- //Signal Handler
- if(signum == SIGINT)
- isrunning = 0;
Console Screenshot:
Reference:
