weight sensor
Discussion in '8bit Microcontrollers' started by jim shirreffs, May 18, 2008.
  1. Does anyone know where I can get an low cost weight sensor? I have looked
    and looked and looked but can't find one anywhere. I know they exist since I
    can buy a digital bathroom scale for under $20 usa and the bathroom scale
    has 4 sensors (strain gages) built into it. Unfortunately a strain gage
    requires some kind of signal amplification that is beyond my limited
    abilities to assemble.
    What I would like to find is a component that has the strain gage and the
    signal amplification all build into it. The load would be in the 20 - 90 lbs
    range.
    thanks in advance to any and all that reply.
    #1
    1. Advertisements
  2. Thanks for taking the time to reply. I want to prototype an idea I have and
    if the idea truns out to be a good one then perhaps go into low volume
    production. My problem is that I am a computer programmer not an electrical
    engineer. So I am trying to find low cost components that I can assemble on
    a bread board for a prototype.
    I did find this at
    http://www.alibaba.com/product-gs/2...acelog=detailtop12907&newId=205545910#page960
    Model CZL902
    Rated load: 50KG
    rated output: 1.0+-0.15MV/V
    dimensions: 34*34*7.8(mm)
    Cable spec: 0.8*420mm
    To my simple non-ee mind it looks like this might be useable out of the box.
    I am hoping to find one I that I can just read the voltage and then compute
    the weight.
    jim
    jim shirreffs, May 26, 2008
    #2
    1. Advertisements
