N
N_Cook
http://home.graffiti.net/diverse:graffiti.net/miniscope9.jpg
Made for ultra portability fits in an 8x11x 2.5 inch case when the thyratron
and vibrator are removed from the chassis and stowed near the hinge. What
war time use was there for such a small 'scope, with in-the-field 12V supply
capability?
War finish presumably means the off white enamel rather than black crackle
finish.
Plate on the brown casing lid
Miniscope
Miniature C/R oscilloscope
Pattern No 58259
Stencilled labels on the case are
R.L. 4
and No 1
Presumably somewhere would have info on the pattern number.
Even using "-dr who" googling does not find anything on Miniscope or that
pattern number, plenty on the 6K25 thyratron but nothing on 9 pin VR91,
10E/92 voltage regulator? or 9 pin CRT
VCR 522, 10E/787, Design Inspected CRT 4
(shattered probably when the shoulder carrying strap broke and corner brace
broke off and split occured in the "suitcase" )
no other valves,
also Masteradio G650 12V vibrator, military trident symbol in a couple of
places , after an A on the VR91 and before a Z on the CRT
side panels missing, someone has crudely bodged in pot .
http://home.graffiti.net/diverse:graffiti.net/miniscope1.jpg
http://home.graffiti.net/diverse:graffiti.net/miniscope2.jpg
http://home.graffiti.net/diverse:graffiti.net/miniscope3.jpg
http://home.graffiti.net/diverse:graffiti.net/miniscope4.jpg
specs etc on hinge-down, prop-up plate
http://home.graffiti.net/diverse:graffiti.net/miniscope5.jpg
http://home.graffiti.net/diverse:graffiti.net/miniscope7.jpg
capability?
finish.
Miniscope
Pattern No 58259
R.L. 4
and No 1
no other valves,
