D
Dantanna
The main point of my question is to get a general idea on what kind of power
usage AC power adapters consume when plugged into a household outlet. Why?
Because even if you have nothing feeding off of the walwart it is still warm
to the touch and that would indicate that it is wasting electricity and
costing money.
For example - I have a Sony Clie which is a rechargeable version of a Palm
Pilot. I noticed that the adapter is rated to output 5.2V at 2000mA. My
first thought was wow! What does a Palm Pilot need 2 Amps for??? So does
the output rating with the Palm Pilot out of its cradle mean that the
walwart is burning up my AC putting out a constant 5V/2000mA?
Are they putting out a steady voltage and only providing current when
current is called for? Or is the current also measurable even with the
device absent?
Bottom line is if these things are consuming power in idle mode - they need
to be updated to be intelligent enough to turn off when the downstream
device is off or removed.
costing money.
device absent?
