Voltage regulator with Vin up to 40 V DC
Dkuriloff
Jan 18, 2010
6
Jan 18, 2010
6
Hi all:
I have a circuit that needs ~ 35 volts DC (unregulated) @ 8 AMPS to drive a flyback primary coil and a oscillator controller circuit using a UC3844 that requires 18 volts regulated + DC @ 500ma. My stepdown 8 amp transformer gives ~27 volts from the 120 v mains and after full bridge rectification and filtering I get 37-38V (no load). I want to use the same transformer for both parts of the circuit. It is center tapped. I can use an LM7818 and a few series diodes to drop the input DC voltage from the transformer to below 35Vin (max for the LM 7818) or an adjustable voltage regulator like the L200.
I thought the the L200 would be a more versatile solution since I could eliminate the voltage dropping diodes. Any thoughts?
What are the differences between the L200, L200C, L200CV, L200CH?
Where can I purchase just 10 pieces without the shipping costing more than the parts?
Is there another more available adjustable voltage regulator that can tolerate 38-40 volts DC in (rectified AC, filtered DC) and output 15-18 volts at ~ 500 ma??
Here is the circuit: volny.cz/jmartis/qrv4_en_final.png
Thanks for the help
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
The UC3844 requires at least 17.5V to assure turn-on. Too bad that excludes using the center tap as a (reliable) power supply for it.
There is an LM317HV that can stand up to 60V Input-Output Voltage Differential & 1.5A.
The datasheet for the L200 says it can stand 40V (& 60V for 10ms) but also gives an example of how to allow for continous input voltages above 56V. It also says that the operating junction temperature for L200C is -25 to 150 °C, & for L200 it is -55 to 150 °C.
The T stands for TO-3, but I'm unable to find the meaning of the H & V.
Have you tried ebay? China & Hong-Kong based companies often have "free" shipping.
