Voltage reduction question
Discussion in 'General Electronics Discussion' started by C0st, Feb 11, 2018.
  1. C0st
    C0st
    Feb 11, 2018
    3
    I have an old alarm system I would like to connect to a raspberry pi,
    the alarm system uses a voltage of 4.5v for digital 0 and 9v for digital 1
    I need somehow to reduce 4.5v to close to 0 volts and 9v to 3.3v for digital 1 of the raspberry pi.
    Voltage divider circuit with a zener is the best I could do but it doesn't achieve the close to 0 :)
    Any help would be appreciated.
    C0st, Feb 11, 2018
    #1
    1. Advertisements
  2. C0st
    7,943
    1,447
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Welcome to EP.
    The quality solution is a comparator with 5 V output. Divide the input voltage down by e.g. a factor 4 (1.125 V low, 2.25 V high), set the treshold to ~1.7 V and you're set.
    The cheap solution is a 5.6 V zener diode, transistor and a few resistors:
    Note that this circuit inverts the signal 4.5 V in -> 5 V out, 9 V in -> 0 V out but that can easily be handled on the raspbery in software.
    Harald Kapp, Feb 11, 2018
    #2
    1. Advertisements
  3. C0st
    C0st
    Feb 11, 2018
    3
    Thank you very very much, gonna try it soon. Won't the 5v fry the Rpi gpio?
    C0st, Feb 12, 2018
    #3
  4. C0st
    7,943
    1,447
    Right, I came up with this rather quickly. Of course, it the raspberrie's I/O is 3.3 V use Vcc=3.3 V.
    Harald Kapp, Feb 12, 2018
    #4
  5. C0st
    C0st
    Feb 11, 2018
    3
    Thank you so so much!
    C0st, Feb 13, 2018
    #5
  6. C0st
    AnalogKid
    Jun 10, 2015
    1,996
    562
    Ohio - GMT-5
    100K from the base to the emitter?
    ak
    AnalogKid, Feb 13, 2018
    #6
  7. C0st
    7,943
    1,447
    will not hurt ;)
    Harald Kapp, Feb 13, 2018
    #7
    1. Advertisements
