L
L D
I have a Xerox 5820 copier that had light areas on copies, mostly
centered on each side of the copy. It wasn't too bad, but still
wasn't the quality it should have been. It repeated every third copy
so thought it was a drum problem. (8 1/2 x 11 paper in landscape)
Replaced the drum and toner cartridge with brand new genuine Zerox
parts. Now one copy is good, but the next two have a white band
(void) about 1 1/2" wide from top to bottom on the left third of the
copy. Looks like the problem was not the parts replaced.
Is there a cleaning procedure that might help fix this or ???? Open
to all suggestions. Thanks
