Vertical T5s
P
Phil Allison
**Hi,
see pic of local council building with many hanging fluoros in foyer:
http://www.denhamconstructions.com.au/img/projects/ashfield-civic-centre_1.jpg
The hanging tubes appear to be T5s and there is NO enclosure.
An internal metallised strip is visible running end to end.
The low end has a neat fitting, white plastic cover.
Light emanates from all around the tube.
Google turns up nothing like it on offer.
What is it ?
.... Phil
A
Andrew Gabriel
**Hi,
What is it ?
A close-up would help.
Ryness Electrical always have something like this on display in
their shop window, but I can't find it on their website.
http://goo.gl/maps/PoNb2
I've seen them used in other shops - more usually they are tied
up horizontally, but they can hang vertically.
P
Phil Allison
"Andrew Gabriel"
"Phil Allison"
** It looks exactly as I described.
I even asked the former mayor of Ashfield ( cnr Ted Cassidy) and was assured
the tubes were regular fluoros.
But regular fluoros do not work when connected at one end only.
.... Phil
A
Atlantic Illumination Entertainment Lighting
Phil said:
...regular fluoros do not work when connected at one end only.
*** Perhaps there are unseen wires up a hidden side of the tubes.
I can't take the time to view the URL, but if there are caps on the
exposed ends, this might be the case.
