Variac VA
Sinewave
Feb 15, 2013
129
Feb 15, 2013
129
Hi, I've got a Varic which I'm told is 2.2kva. There is no data plate on it. What do you think is a reasonably accurate way of finding out what it's rating really is?
Sinewave
Feb 15, 2013
129
Feb 15, 2013
129
Measurements are approx as I don't want my steel rule coming into contact with the windings.
Outside diamater 130mm
Height 95mm
and these are the measurements of the actual windings.
It's an open variac, would the weight help? It is rather heavy and needs two very strong and steady hands to move it!
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
That seems quite small. Yeah the weight might help.
I have a 750VA variac and that is about the same dimensions. If I have time I'll open the box and measure the dimensions
(*steve*)
25,510
25,510
Here is a picture of mine. It's about 70mm tall, and 120mm diameter.
And here's the front panel. (Not that I think it's useful)
Sinewave
Feb 15, 2013
129
Feb 15, 2013
129
I'll measure it again, maybe I got it wrong.
I was happily running it tonight (or last night now) at 4amps for a while and for a few moments ran it at 9 amps. It didn't even appear warm. Though it was sold to me in good faith as a 2kva (or 2.2 can't remember), I just wanted to be sure.
At work we have one rated at 10 amps ( I know transformers are better rated in VA) and the one at work isn't any bigger.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
The current limit will be more to do with the brush connection rather than the wire diameter. In this respect, current limit is a better measure than VA. VA will depend on set output voltage.
Sinewave
Feb 15, 2013
129
Feb 15, 2013
129
Today I opened our variac at work. It is labelled as 10 amps. The wire gauge appears the same as mind. The transformer measures 160mm by 85mm high, which is a little wider than mine, but not as tall, which I think seems consistent with a difference of 2 amps in rating between them.
(*steve*)
25,510
25,510
It's worth noting that for any load neither the VA or the current limit should be exceeded.
Ok, you can exceed them a little for a short duration.
But if you input voltage is 240V and your output is 20V, don't even think for a moment that you can use the VA rating to determine the max current. As @duke37 has said, the brush is a limiting factor, but also the windings do not use a gauge of wire that will be up to the task of the current at low voltages for a constant VA.
Sinewave
Feb 15, 2013
129
Feb 15, 2013
129
You can use the input voltage to determine the max current, but not the variable output voltage. The non variables (max VA) aren't going to move as the voltage varies.
2kva at 20v would assume 166va, or 2kva at 20v in a calculation would be 100 amps, which I don't think anyone in their right mind would ever think can magically appear from an 8 amp/2kva variac.
