vinod chandran
- Jun 21, 2011
- 192
- Joined
- Jun 21, 2011
- Messages
- 192
Hi again.
I take it you got the idea now, Duke37's post above should have explained it as simple as is possible, any way the link to the site i left covers lots of different components, tips, and some projects, all in all its a good site, a lot can be learned in there. Dave.
This is a variable resistor going from about zero to about 100k. Resistors can be connected either way round so you could interchange p1 and p2/p3 without problems.
There may well be an optimum way of connection in that the control would work the oposite way wih the connections the other way round. Volume controls on radios increase the sound level when turned clockwise, it would be strange if they needed to be turned anticlockwise to increase the sound.
Some variable resistors are linear, the resistance changes by an equal amount as the control is changed, some have a logarithmic response and some an antilog response to make the resistance change more sensitive to rotation at one end or the other.
I know this will probably confuse you, but you can also connect p1 p2 and p3 to all different connections and then p2 would be more like a variable voltage pin out. Since the resistance on either side makes up a voltage dividing network.
