John said:
I read in sci.electronics.design that Jacques St-Pierre
about 'Variable reluctance magnetic pickup signal conditionner', on Sat,
28 Aug 2004:
Twist the two conductors together tightly. That approaches the effect of
a shielded wire.
Another interesting aspect of this circuit is that the 20M resistor is
not for hysteresis like everyone thinks- its current is strictly
common-mode and produces no hysteresis whatsoever. So what does it do?
Leave it to the practical applications experts at National to use this
resistor to swamp the output transition dV/dt induced current through
the inevitable Cstray to each input- after all, that input is
differential open loop, relatively high impedance, with a gain of
200,000 reacting to mV signal levels -and that output is transitioning
12Vp-p or whatever the original app was. So 20M was chosen so that
d(i(+))=d(Vout)/20M to In(+) swamps d/dt(Vout) x Cstray to In(-). By
similar reasoning, he will need shielded twisted pair to the pickup.
This also happens to be one application where input offset saves the
day, because it is the offset that overdrives the noise in the absence
of pickup signal. Therefore, once he tames pickup noise, he should also
consider applying a deliberate offset to that In(+) terminal through an
arrangement like this:
View in a fixed-width font such as Courier.
+----------------+------------+--<8V
/ 390K R
10K / /p
\ | 20M |
| 1K | |\ |
---\/\/\/\/--|--------+ | >---+---OUT
PU | | /
10K
