Z
Zach Zaborny
Hello all,
I am working on a low amperage variable power supply for use with some of
my logic circuits that only require a few milliamps. The schematic for it is
located at:
http://random.nts-technologies.org/images/Hosted/powersupply.gif. The
circuit itself is based on the car battery charger circuit located at:
http://www.interq.or.jp/japan/se-inoue/e_car2_1.htm (because it supplies a
voltage and current similar to the one I want) with a few minor changes to
up the voltage and current ranges (resistor values). Upon setting up the
circuit on my breadboard, notice that when a load is put on the output,
like a cassette deck motor or an LED, the voltage meter returns to 0. Is
there any problems in the circuit which can cause that to happen? Could it
perhaps be a faulty voltage/current regulator? I have also seen many voltage
meter applications that have a resistor across the meter's terminals, would
that be needed? If so, what value?
I am a beginner and this is my first big project, so any ideas and
improvements on my circuit are extremely welcome.
Thanks in advance,
Zach, NTS
located at:
Thanks in advance,
Zach, NTS
