Value of RF (feedback resistor formula)
qwerty22
Nov 10, 2013
Nov 10, 2013
I need help as I have the answer but I don't know the formula
its an 741, with vi 1Vpp, input resistor is 10k, Value of output signal 10Vpp
I have to work out RF which is 100k, I did the usual **** 1vpp = 10k
10 vpp=10k x 10= 100k
But not the proper formula so I though this:
AV ( idk what it is) = 10v/1v = RF/10k =10
so RF = 10k*10 = 100k
Is that the formula? i need to show proper formula as working out, which i don't know,
however the answer is correct...
I can't seem to find the formula online anywhere btw.
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
Instead of trying to find the correct formula, why not derive it yourself? Just realize two facts:
1. When the 1 Vp-p input is at +1V the 10 Vp-p output is at -10V.
2. The '-' input to the opamp is a virtual ground. The '+' is tied to real ground and negative feedback keeps the '-' input at the same voltage as the '+' input (within a few microvolts).
attachment.php
So what you have there is a simple voltage divider where 11 volts is divided between Rin and Rf. Solve that and you have the correct formula for finding Rf.
