A
Adam Funk
A kid's ceiling night-light, which shines planets, stars, &c., over
the walls & ceilings, has failed (after several years & changes of
tiny 12 V halogen lamps). I've been asked to see if it can be fixed.
The lamp-holder inside the globe has corroded & is no longer usable.
The whole thing consists of the following:
a wall-wart with a British plug & AC output, labelled
PRI 220-240V~ 50 Hz 0.1A
SEC 11.5V~ 10-20 W
SELV
a plug that fits into the wall-wart, cabled through an in-line
switch, to the lamp-holder, which clicks & twists into the globe
the globe, which is just a plastic sphere (more or less) with
colored disks to shine various shapes on the wall & ceiling
My first thought was to put a rectifier bridge on the SELV output &
then a few white LEDs with series resistors, but then I wondered ---
why not use either
1. a suitable resistor in series with a rectifier bridge arrangement
of LEDs,
or
2. a rectifier bridge arrangement of series resistors & LEDs
Adam
SEC 11.5V~ 10-20 W
SELV
why not use either
of LEDs,
or
Adam
