M
Mike
Hello
After a failed attempt to utilize a hot water heating system using an
interior woodstove to heat water and pipe it to radiators in my detached
garage (not though out) someone suggested that I make a "water heater" with
an electric element and use this to heat the garage. The water heater would
be in the house basement complete with a pop valve. He said that if I had a
storage tank that this would be more efficient than using an electric heater
in the garage. There are approximately 150 feet between the house and
garage with 2 insulated 3/4 inch lines buried between the two. My gut
feeling is that the electric heat is 100 % efficient so it would work better
to simply buy a heater for the garage- buttttttt- if I use the tank in the
basement any lost heat would simply add to the house heat anyways so that is
not really a loss. I don't know how the storage tank (thinking of a 30
gallon heavy plastic barrel) and the loss from the ground would come into
play. I already have two finned rads in the garage. Also there is 220
available in the garage. I guess that I would have to put a new breaker in
the basement for the element if I go with that idea. The garage is a single
one with insulation and lining. Right now it is 30 below celcius that
helps.
Anybody out there that would like to give me their ideas on the plan "or
lack of".
Thanks in advance
Mike
helps.
lack of".
Thanks in advance
Mike
