O
Oliver Fleming
I am running Seaclear software. My Laptop has no Serial port.
I am using a Ritmo USB to Serial connector.
The serial connection runs to a Noland Multiplexer.
I receive data OK and the moving map works just fine, however when I
create a route for the Autopilot to follow the signal does not seem to get
through and the pilot sends off the alarm.
I have tried tis with Fugawi and OziExplorer with the same result.
However when I use the old Compaq M700 with a serial port it all works
perfectly.
I think the USB to Serial converter is not working correctly or I need a
different kind. I have tried the different drivers availabe on the
respective web sites but still the same result.
Any ideas out there for me?
Oliver Fleming
perfectly.
Oliver Fleming
