Hi Paul,
Don Y wrote:
[%X---stuff on Toyota Unintended acceleration event -- %X]
I've gone through a similar exercise with "theft prevention" in mind
(aftermarket being far preferable to factory installed as it would
be less ubiquitous -- less likely to be a "known" to a would-be thief),
In your specific case, "neutral" is your friend! :>
Absolutely.
It always amazes me how easily people seem to panic/lose all
sense of reason in these situations! :-(
I have had cars with mechanical failures of the clutch, throttle linkage and
accelerator pedal springs at various times. Even one with a gear-box that
decided to be extremely random about which gear it would let you have. All
still limped home for remedial work OK. All of the recovery actions that
should be common sense to all drivers (sadly it does not seem to be) always
worked well enough for me. This was, however, before the ECU became an
addition to the vehicles. Only had a failed hydraulic clutch system since
then and still managed to get that home as well.
I once lost a wheel bearing in one of the front rotors (disintegrated).
The wobble in the rotor was enough to forcibly drive the calipers
apart rendering the hydraulics useless.
I discovered this in rush-hour freeway traffic while driving in the
left lane (65+). And, still quick-witted enough to think of stomping
on the "parking brake" before ass-ending the bloke in front of me!
*And* aware enough of the latching nature of that mechanism (a pedal
in my case) to simultaneously reach down and grab the "ratchet release"
so the pedal didn't stay locked.
I drove the 20 miles home "hunched over" so I could keep my hand on
that release to "unapply" the brake each time I stepped on it! :-/
Thankfully, didn't mangle the spindle so it just cost me a rotor
and bearing (and an hour of my time)! Though, in the process,
discovered that the shop I had brought the car to many years before
had neglected to re-install one of the components that allowed the
"parking brake" to work correctly -- which accounted for its
poor performance in this situation! (maybe a GOOD thing?)
That was the event that convinced me not to let anyone work on
my vehicles -- regardless of how "easy"/routine the task! :<
Now consider the emergence of the Electric Vehicles into the general
populace. Having loked for the current "Construction and Use Regulations
(UK), there was only mention of the charging points for such vehicles.
Thankfully the United Nations has something (see UN100):
"5.2.2.3 Unintentional acceleration, deceleration and reversal of the drive
train shall be prevented. In particular, a failure (e.g. in the power train)
shall not cause more than 0.1m movement of a standing unbraked vehicle."
Perhaps this should apply to all vehicles anyway.
Doesn't say anything about how you can "enforce" a "brake". Or,
disengage the drive if it doesn't want to! (would they call that
"unintended ignorance of intended operations"?? :> )
When things *work* is not when you have the problems! :-/
