- Joined
- Dec 18, 2013
- Messages
- 5,178
If that trace is 20 mV per division then it's greater than 80 mV. Just out of interest what wave shape were you using from your signal generator when you did the test with it?
Cheers
Adam
Cheers
Adam
Cheers
Adam
In addition to the signal to be measured, did you also provide ground connection from your circuit to the frequency counter, or did you assume that the frequency counter is grounded?
That frequency counter is unusual for a mains device in that the BNC outer connections are not grounded.
Can't think of any other reason to explain your symptoms.
Have you connected it to both the scope and the counter to make sure the counter is not loading the signal and degrading it, or even stopping the oscillator?
The write-up for the frequency counter says:
"Channel A (0.01Hz to 50 MHz)
Frequency range : DC couple 0.01Hz to 100 Hz, AC couple 100Hz to 50 MHz
Sensitivity :
"DC" 0.01 Hz - 1 Hz ≤ 500m Vp-p , 1 Hz - 100Hz ≤ 80m Vrms
"AC" 100 Hz - 50 M Hz ≤ 80m Vrms "
Should that be interpreted as requiring 80mV minimum or maximum? I think the former, especially in view of the sensitivity figure given for 0.01Hz-1Hz. Try a bigger signal than what you've been feeding it so far.
